Hello.
I don't know if I'm publishing it at the Corector site
Although the catalog is for movie themes, I am using it as a
Catalog of cooking.
I have the recipes downloaded in a directory of my hard drive in JPG format, and
 The import method is 4 - External Picture with Relati
I use the extras to see the recipes which download them in photo format.
These recipes often update them for a new recipe by erasing the previous one.
I wondered if there would be any way of having a scripts that could be checking
All records, to check whether that .jpg file exists or not in the Board of Directors
of the hard drive.
Because I imagine that the name of the file of the cover or extras in some field
It has to be included.
In this way when I would not find the file (extras) you could have a field
Personalized to know what registration you have to review example: "Check"
Forgive if I have not explained well.
Scripts programming is almost impossible for not having many knowledge
of programming.
Thank you very much for your help.
