How to Use XML Exportacion in the Web
Filibustero
Post by Filibustero »
First, Thanks for this wonderful software, I love it.
This is my question. I saved my Data Base like XML. I don´t kow anything about using this language. I have experience using Dreamweaber in order to create my Html pages and serving pages from my Server at home. Could you please tell me how use this XML file in my pages.
Thanks from Spain :)
Twink made a template for that.
See the file "template from Twink (4).zip" in the "Templates" folder.
There is a readme file in it, and a topic about it on the "Scripts & Templates" section of this forum ;)
There are probably easier/other ways to use this xml file on the web.
You can make a .xsl file. Or a PHP or ASP script maybe ?
Twink
Post by Twink »
Willspo's new template supports xml too, and works better then my template in it's current state
dmoolkye
Post by dmoolkye »
I just like the fact that he typed "EXPORTACION"
:grinking:
Kinda like Transmogrified
