Request: Way to link scripts together (batchmode)
Nik0
Post by Nik0 »
could you please add a possibility to link scripts, eg. first start script ofdb, then script xy, then script za.
I tried to make a big script like imdb-ofdb, but i failed. :(
Nik0
Why do you post that in "bug report"? It is not a bug, it is just a functionnality that does not exist :p
Nik0
Post by Nik0 »
i posted my last request also here...it was fine at that time :wink:
viewtopic.php?t=2743
but, what about my request :??:
That's just that I forgot to indicate that at that time, but also that the fact that referer info could not be provided could be seen as a bug (i.e. lack of an important feature), unlike the non-possibility of combining scripts.
Nik0
Post by Nik0 »
okay, next time i'll post in the "Comments"-area
meanwhile, could you please move this thread to wherever you want it to be and give my little idea a second try?
It would really be a cool thing to just enter the name of the movie, push F6 and all three scripts will be processed.
OK it is moved ;)
About the idea of combining scripts, the only thing that could be added is the ability to select more than 1 script to run.
But they will never really be combined as on each site the title search has to be done.
