Feature Request - Printing of a Movie List
Hi there, I'm a great fan of your program, there is just one thing, I'm missing a bit, could you include a Print Option for printing out the movie list? I know I can export them to HTML and then print then but would be nice if I could print out the list directly. Sorry if anyone has asked this on French but my French is quite bad :)
Keep up the great work!
Hi.
The Printing support will be added, but I cannot say when (which date). I will maybe make soon a small version (3.3.1) to correct some small things, then the next version (3.3.2 or 3.4) will include printing.
