[REQ] Not any german script is working!
mumpel
Post by mumpel »
Hi there,
I was using AMC for a couple of months now and it perfectly fitted my needs.
First I have to say that the import scripts are THE reason for me to switch to AMC. And I'm using the latest version of AMC and checked the board to find a solution for several weeks/months. And finally that I'm not a coder, so I have to rely on other's solutions.
The BIG problem is that since some weeks/weeks, I can't access any german script for importing data. I just can use Amazon.de (Image Only), Cinefacts.de, Filmposter-archiv.de, Lionetwork.net and IMDB.com, OFDB.de and finally OFDB-IMDB. Regulary, I used Cinefacts.de and OFDB.de to immport my data. But now, any of them worked probably.
Amazon.de (Image Only) doesn't request the movie title and always displays "No movie found".
Cinefacts.de always displays "HTTP/1.1 404 Not found".
Filmposter-archiv.de doesn't import anything.
Lionetwork.net and IMDB.com pops up with "HTTP/1.1 403 Forbidden".
OFDB always displays an empty movie list.
And OFDB-IMDB doesn't import any actors.
So what to do? I can't use AMC any more. The script-fix request has be done by others weeks ago and nothing changed. Other requested scripts for other german movie/DVD sites haven't come. So, does this mean that the support for german users has been closed? What's up Antp? Can anybody help? :cry:
Did you try the version of cinefacts & ofdb available from www.antp.be/temp/scripts ?
I do not have time to fix all these scripts personnally (and actually most of the scripts are done by other people, not by me).
Maybe if I have some time and if I do not forget I will check some of them, but it is strange that there are no German user that can do that, like some of the French users do for the French scripts :??:
Viridarium
Post by Viridarium »
I've fixed the cinefacts.de-Script:
program CineFactsDE;
  CRLF = #13#10;
  MovieURL: string;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function MyTrim(str_: string): string;
  chars: array of char;
  StrLen, i, LastSpacePos: integer;
  result := '';
  str_ := StringReplace(str_, #9, '');
  str_ := StringReplace(str_, #10, '');
  str_ := StringReplace(str_, #13, '');
  while Pos(' ', str_) = 1 do
    Delete(str_, Pos(' ', str_), 1);
  StrLen := Length(str_);
  SetArrayLength(chars, StrLen);
  for i := 0 to StrLen-1 do
    chars[i] := Copy(str_,i+1,1);
  str_ := '';
  LastSpacePos := StrLen - 1;
  if LastSpacePos > -1 then
    while chars[LastSpacePos] = ' ' do
      LastSpacePos := LastSpacePos - 1;
    for i:= 0 to LastSpacePos do
      str_ := str_ + chars[i];
  str_ := StringReplace(str_, '  ', ' ');
  while result <> str_ do
    result := str_;
  result := StringReplace(result, ' ,', ',');
procedure CutAfter(var str_: string; Pattern: string);
  str_ := Copy(str_, Pos(Pattern, str_) + Length(Pattern), Length(str_));
function GetStringBetween(str_, StartTag, EndTag: string): string;
  BeginPos, EndPos: integer;
  result := '';
  if EndTag = '' then
    EndPos := Length(str_);
    EndPos := Pos(EndTag, str_);
  BeginPos := Pos(StartTag, str_) + Length(StartTag);
  if StartTag = '' then BeginPos := 1;
  if BeginPos > 0 then result := Copy(str_, BeginPos, EndPos - BeginPos);
function GetTrimmedStringBetween(str_, StartTag, EndTag: string): string;
  result := MyTrim(GetStringBetween(str_, StartTag, EndTag));
// Extracts single movie detail (like director, genre) from page
  Result := '';
  Page := StringReplace(Page, 'ß','ß');
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
//    HTMLRemoveTags(Result);
    HTMLDecode(Result);
function StripHTMLTags(str_: string): string;
  temp_char : char;
  StrLen, i, CharPos : integer;
  DoCopy : boolean;
  DoCopy := true;
  CharPos := 0;
  result := '';
  for i := 1 to StrLen do
    temp_char := Copy(str_,i,1);
    if temp_char = '<' then
      DoCopy := false;
      continue;
    else if temp_char = '>' then
      DoCopy := true;
      continue;
      if DoCopy then
        result := result + temp_char;
procedure AnalyzeIndexPage(Address: string);
  IndexPage: TStringList;
  Page : String;
  IndexPage := TStringList.Create;
  Address := URLEncode(Address);
  IndexPage.Text := GetPage(Address);
  PickTreeAdd('Search results', '');
  AddMoviesTitles(IndexPage);
    Page := GetPage(Address);
    AnalyzeMoviePage(Page, Address);
  IndexPage.Free;
procedure AnalyzeMoviePage(Page, Address :String);
  TomString, Line, Temp, Value: string;
  LineNr, IntValue: Integer;
  BeginPos, EndPos: Integer;
  StrPosition: Integer;
  StrTemp,srcPic, MovieID: string;
  OriginalTitle, Country, Year, Genre, Studio, Region, EAN_Number, Distributor, AFK, Duration: string;
  VideoFormat, ScreenFormat, ScreenSystem, Language, AudioFormat, Subtitle, MediaType, Disks: string;
  Comments, Bonusmaterial, Packaging, TranslatedTitle, Director, Cast, Producer, Description: string;
  Music, Screenplay: string;
// Initializing the very important Comments
  Comments := '';
// URL
// Translated title
  TranslatedTitle := MyTrim(GetStringFromHTML(Page,'span class="headline">','">','<br>'));
  SetField(fieldTranslatedTitle, TranslatedTitle);
// Original-Title, Country and Year
  OriginalTitle := MyTrim(GetStringFromHTML(Page, 'Originaltitel:','"first">','(<a href="'));
  StrTemp := MyTrim(GetStringFromHTML(Page, '"land_list.php?name=','">','</dd>'));
  StrTemp := StripHTMLTags(StrTemp);
  StrTemp := GetTrimmedStringBetween(StrTemp,'(',')');
  Country := Copy(StrTemp,1,Length(StrTemp)-4);
  Year := Copy(StrTemp,Length(StrTemp)-4,Length(StrTemp));
  SetField(fieldOriginalTitle, OriginalTitle);
  SetField(fieldCountry, Country);
  SetField(fieldYear, Year);
// EAN-Number
  EAN_Number := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">EAN-Nummer:','', '</dd>')));
  EAN_Number := StringReplace(EAN_Number,'EAN-Nummer:','');
  Comments := Comments + 'EAN-Nummer: ' + EAN_Number + CRLF;
// Genre
  Genre := '';
  Genre := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Genre:', '', '</dd>')));
  Genre := StringReplace(Genre,'Genre: ','');
  setField(fieldCategory, Genre);
// Studio
  Studio := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Studio:','', '</dd>')));
  Studio := StringReplace(Studio,'Studio: ','');
  Comments := Comments + 'Studio: ' + Studio + CRLF;
// Distributor
  Distributor := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Vertrieb:','', '</dd>')));
  Distributor := StringReplace(Distributor,'Vertrieb: ','');
  Comments := Comments + 'Vertrieb: ' + Distributor + CRLF;
// Altersfreigabe
  AFK := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">FSK:','', '</dd>')));
  AFK := StringReplace(AFK,'FSK: ','');
  Comments := Comments + 'Altersfreigabe: ' + AFK + CRLF;
// CountryCode
  Region := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Ländercode:','', '</dd>')));
  Region := StringReplace(Region,'Ländercode: ','');
  VideoFormat := 'DVD Zone '+Region;
  setField(fieldVideoFormat,VideoFormat);
// Duration
  Duration := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Länge:','', '</dd>')));
  Duration := StringReplace(Duration,'Länge: ','');
  Duration := StringReplace(Duration,' Minuten','');
  setField(fieldLength,Duration);
// Description
  Description := GetStringFromHTML(Page, '<li class="text c1">','', '</li>');
  Description := StringReplace(Description, '<br />','*');
  Description := MyTrim(StripHTMLTags(Description));
  Description := StringReplace(Description, '*',CRLF);
  setField(fieldDescription,Description);
// Actors
  Cast := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Schauspieler:','', '</dd>')));
  Cast := StringReplace(Cast,'Schauspieler: ','');
  setField(fieldActors,Cast);
// Director
  Director := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Regie:','', '</dd>')));
  Director := StringReplace(Director,'Regie: ','');
  setField(fieldDirector,Director);
// Production
  Producer := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Produzent:','', '</dd>')));
  Producer := StringReplace(Producer,'Produzent: ','');
  setField(fieldProducer,Producer);
// Music
  Music := '';
  Music := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Musik:','', '</dd>')));
  Music := StringReplace(Music,'Musik:','');
  Music := StringReplace(Music,' Minuten','');
  Comments := Comments + 'Musik:' + Music + CRLF;
// Screenplay
  Screenplay := '';
  Screenplay := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Drehbuch:','', '</dd>')));
  Screenplay := StringReplace(Screenplay,'Drehbuch: ','');
  Comments := Comments + 'Drehbuch: ' + Screenplay + CRLF;
// Screen format & system
  ScreenFormat := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Format:','', '</dd>')));
  ScreenFormat := StringReplace(ScreenFormat,'Format: ','');
  ScreenSystem := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">System:','', '</dd>')));
  ScreenSystem := StringReplace(ScreenSystem,'System: ','');
  setField(fieldResolution,ScreenSystem + ' - ' + ScreenFormat);
// Audioformat/Language
  AudioFormat := '';
  Language := '';
  StrTemp := GetStringFromHTML(Page, '<dt class="c1">Tonformat:', '', '<dt class="c1">Untertitel:');
  StrTemp := StringReplace(StrTemp, '</dd>','*');
  StrTemp := MyTrim(StripHTMLTags(StrTemp));
  StrTemp := StringReplace(StrTemp,'Tonformat: ','');
  while Pos('*',StrTemp) > 0 do
    AudioFormat := AudioFormat + ', ' + MyTrim(Copy(StrTemp,1,Pos(' in ',StrTemp)));
    Language := Language + ', ' + MyTrim(Copy(StrTemp,Pos(' in ',StrTemp)+4,Pos('*',StrTemp)-(Pos(' in ',StrTemp)+4)));
    CutAfter(StrTemp,'*');
  AudioFormat := Copy(AudioFormat,3,Length(AudioFormat));
  Language := Copy(Language,3,Length(Language));
  setField(fieldAudioFormat, AudioFormat);
  setField(fieldLanguages, Language);
// Subtitles
  Subtitle := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Untertitel:', '', '</dd>')));
  Subtitle := StringReplace(Subtitle,'Untertitel: ','');
  if Subtitle = 'Keine Untertitel' then Subtitle := '';
  setField(fieldSubtitles, Subtitle);
// Mediatype
  MediaType := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Medientyp:','', '</dd>')));
  MediaType := StringReplace(MediaType,'Medientyp: ','');
  setField(fieldMediaType, MediaType);
// Disks
  Disks := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Medienanzahl:','', '</dd>')));
  Disks := StringReplace(Disks,'Medienanzahl: ','');
  setField(fieldDisks, Disks);
// Package
  Packaging := MyTrim(StripHTMLTags(GetStringFromHTML(Page, '<dt class="c1">Verpackung:', '', '</dd>')));
  Packaging := StringReplace(Packaging,'Verpackung:','');
  Comments := Comments + 'Verpackung: ' + Packaging + CRLF;
// Bonusmaterial
  Bonusmaterial := MyTrim(GetStringFromHTML(Page, ' BONUS-MATERIAL </li>', '', '</ul>'));
  Bonusmaterial := StringReplace(Bonusmaterial,'</span>','*');
  Bonusmaterial := StringReplace(Bonusmaterial,'<li>','-');
  Bonusmaterial := MyTrim(StripHTMLTags(Bonusmaterial));
  Bonusmaterial := StringReplace(Bonusmaterial,'BONUS-MATERIAL','');
  Bonusmaterial := StringReplace(Bonusmaterial,'*',CRLF);
  Comments := Comments + CRLF + 'Bonusmaterial' + CRLF + '===========' + CRLF + Bonusmaterial + CRLF;
  setField(fieldComments,Comments);
  if CanSetPicture then
    MovieID := Copy(Address,Pos('?id=',Address)+4,Length(Address));
    if GetOption('BigPicture') = 1 then
      srcPic := 'http://www.cinefacts.de/bild.php?id=' + MovieID + '&type=db&studio=' + StringReplace(Studio,' ','')
      srcPic := 'http://www.cinefacts.de/bild.php?id=' + MovieID + '&type=ds&studio=' + StringReplace(Studio,' ','');
    GetPicture(srcPic);
  //DisplayResults;
procedure AddMoviesTitles(ResultsPage: TStringList);
  Page,str_: string;
  sNr,pNr,aPage : Integer;
  MovieTitle, MovieAddress: String;
  Page := ResultsPage.Text;
  snr := 0;
  str_ := MyTrim(StripHTMLTags(GetStringFromHTML(Page, 'Anzahl Ergebnisse gesamt:', '', '</li>')));
  str_ := StringReplace(str_,'Anzahl Ergebnisse gesamt: ','');
  pNr := StrToInt(StringReplace(str_,')',''),1);
  aPage := 1;
  while sNr < pNr do
    while Pos('details.php?id=', Page) > 0 do
      CutBefore(Page, 'details.php?id=');
      MovieAddress := 'http://www.cinefacts.de/dvd/db/' + GetStringFromHTML(Page, 'details.php?id=', '', '"');
      MovieTitle := MyTrim(GetStringFromHTML(Page, 'details.php?id=', '">', '</tr>'));
      MovieTitle := StringReplace(MovieTitle, '</td>', ' | ');
      MovieTitle := MyTrim(StripHTMLTags(MovieTitle));
      CutAfter(Page, '</tr>');
    sNr := sNr + 50;
    aPage := aPage + 1;
    if sNr < pNr then
    Page := GetPage(URLEncode('http://www.cinefacts.de/suche/suche.php?akseite='+IntToStr(aPage)+'&startwert='+IntToStr(sNr)+'&name='+MovieName));
  if CheckVersion(3,5,0) then
    if Input('cinefacts.de Import', 'Filmtitel eingeben:', MovieName) then
      AnalyzeIndexPage('http://www.cinefacts.de/suche/suche.php?name='+MovieName+'&go.x=0&go.y=0');
willow23
Post by willow23 »
THANK YOU Viridarium!!!
The fixed script works well! Good job ! I realy apprecaite your effort! I've tried to fix the script myself, but because I'm not a programmer I failed :-)
THX,
Willow
Bad Joker
Post by Bad Joker »
the ofdb-imdb script is also working again! check this thread:
viewtopic.php?p=21044
mumpel
Post by mumpel »
@ antp:
Of course I was looking for updates scripts and I surely updated the scripts immediately before I posted. ;) And of course I'm not blaming you. I respect your work very much. But I just mentioned the situation for a german user and the immediate need of help.
@ Viridarium:
Thanks a lot for the fix! I really appreciate this. :grinking:
@ Bad Joker:
I found this fix before. Well, at least it's now running better than before ;) Which means that I'll get data but no actors, like I posted in the starter's post. Now I posted this into the thread additionally. Maybe someone can help. :/
