Export to amc
zivija
Export to amc
Post by zivija »
Hello! Is there way to export movies to amc format? I want to make new catalog, and to put some movies from existing to new catalog. Or is there better way to do this?
Thanx!!!
Do a copy of the file or a Save As, then delete unuseful movies in the copy.
You can also import some movies into a new catalog using File -> Import.
zivija
Post by zivija »
Thanx, it works!
