dku
Post
by dku »
Hello,
I'm trying to build a string with several field but one or the other could be empty. So, I've to chekc the length :
Text := Length([MediaType]);
I add this code in the Memo script editor, it returns always 0.
I've also tried with :
Text := Length('Test');
Always 0 ... Becoming crazy...
Any hint ? Length is not working ? Any other to check if a variable is empty ?
Bye Didier
Post
by antp »
You can do
if [MediaType] <> '' then
// it is not empty
dku
Post
by dku »
Thanks for the 'workaround', it works perfectly.
