XML Save - new Names for pictures
kuno21
Post by kuno21 »
Hi
When i save the catalog as XML, and ther are already pictures in the export dir, i will get all pictures exported again, with names like 1_xxxxxxx.jpg. ( the next save will change the xxxxxxx to a new value - so will have a complete serie off all pictures at each xml-saving)
And in the XML-File the last value from xxxxxx will be written.
I turned on that the puctures should not be saved when they allready exist.
Any hints for me
Information
MovieCatalog.exe : version 3.5.0.2 (29.5.2005 12:51:40)
AMCExchange.dll : version 1.0.1.6 (26.6.2004 23:39:24)
AMCReport.exe : version 1.0.2.2 (15.1.2005 16:13:58)
MediaInfo.dll : version 0.6.0.0 (18.5.2005 23:45:58)
(press Ctrl+C if you want to copy these information to clipboard)
OK
You mean if you save several times the catalog without closing/reopening it?
kuno21
Post by kuno21 »
antp wrote:Hi,
No, that happens also if i open AMC with my default database, save to xml and close amc.
each time i do so, i get a new series of all pics.
Strange. Well, it is for sure a bug. I will see if I can reproduce the problem, and fix it for next version ;)
kuno21
Post by kuno21 »
antp wrote:Strange. Well, it is for sure a bug. I will see if I can reproduce the problem, and fix it for next version ;)
TNX's
To configure a seperate picture-Path for XML would be usefull :-))
regards
PS:
For me Webtrack is the best addition to AMC
http://www.snille.net/index.php?info=webtrack
Would be great to cooperate with the guys there
Actually he asked me few questions some time ago:
viewtopic.php?t=3021
in a future version I will probably arrange the XML handling to make it work better with webtrack (and work better at all, since there are some problems...)
I checked and it is maybe not really a bug... if you save a AMC file that has stored pictures to a XML file in a folder where there are already pictures, well the programme cannot guess that all the pictures are related to a previous conversion. It would be a little complicated to handle.
