synchronise
ismanpa
synchronise
Post by ismanpa »
Hello,
How can I synchronise data beteen two Ant movie catalog programmes on two computer?
Thank you1
You mean merge changes made to a catalog on two separate PC?
Nothing is made for that currently, unfortunately.
ismanpa
yes
Post by ismanpa »
Yes, that is what I mean. I can inmport one catalogue into the other and then use the duplicate script, but this is very hard work for hundreds ot items.
Thank you for the reply!
