[REQ] cinefacts.de FIX
Legion
Post by Legion »
Hello there,
well, there is problem with the "cinefacts.de"-Script . The actual version available in http://www.antp.be/temp/scripts/ works almost perfectly, but if you want to get infomation for a movie which is rated with german FSK 18 (suitable only for persons of 18 years and over), you get following error-message:
"IOHandler value is not valid"
This happens since cinefacts.de want a Login, in which you should verify that you are over 18 years.
So, my question: Is it possible to integrate my Login-Data into that script, that i can get information from movies rated "18 and above" again?!
Thanks in advance for any little help ;)
Greetings
Legion
Depends on how the login is handled on the site. If it uses cookies or HTTP authentication it won't be possible.
