AMCphp - Catgegory
screach
AMCphp - Catgegory
Post by screach »
I can't get the categories to work. Everything else works fine accessing the xml file.
Could someone check this out and let me know what's wrong or a demo of one working?
http://www.johnponic.com/Movies/ANT_Mov ... index.html
I put the php in txt form so you can view it:
source for settings = http://www.johnponic.com/AMCphp/settings.txt
source for xml = http://www.johnponic.com/Movies/ANT_Mov ... movies.xml
source for categories = http://www.johnponic.com/Movies/ANT_Mov ... gories.txt
source for parser = http://www.johnponic.com/AMCphp/parser.txt
Thank you,
