mass delete
TruePlaya
mass delete
Post by TruePlaya »
Is there a away to mass delete files? I can pull the list up of multiple files in multiple folders, but is there a way instead of renaming them I just want to delete them. Is this possible?
You mean delete files without deleting the folders? For that I do a search of "*.*" in Windows Explorer and then I select all files and delete them.
TruePlaya
oh MAN!
Post by TruePlaya »
antp wrote:You mean delete files without deleting the folders? For that I do a search of "*.*" in Windows Explorer and then I select all files and delete them.
Oh man! perfect! why didn't I think of that. Thanx again man! :o)
Iron
Post by Iron »
Ctrl+A :cool:
Ctrl+A only works in current folder, or if you do not want to keep folders ;)
