Can I move several movie numbers?
luuuciano
Post by luuuciano »
Can I select some movies and increase their numbers?
It is because I want to add some CDs that I found, and have numbers between some other cds...
(I am using my own coding of course, but it would be nice to sort it by number too)
Select the movies that you want to have their number increased, then Tools -> Scripting, click "Editor" then the "new" icon, enter the following:
program NewScript;
  SetField(fieldNumber, IntToStr(StrToInt(GetField(fieldNumber), 0) + 1));
Then click "Run".
You can replace +1 by the increase that you want.
luuuciano
Post by luuuciano »
wow, what a nice little script...
thank you very much antoine!
