Rename based on clipboard content
rs232
Post by rs232 »
Analyze this:
Say I have a movie folder (movie legally owned of course) and I want to fetch from imdb the original title.
I go to IMDB I copy the original title in the clipboard.
I have my scripts that change characters, put dates in between square brackets etc, they are called via context menu however to add the original title I always have to right click -> Rename, add round brackets, past the clipboard within, etc.
At this point it would also be great to have the possibility via the same antrenamer scriopt to rename the file/folder in question using information from the clipboard content.
So essentially automating something like:
LOST ILLUSION 2021
into
Lost Illusions (Illusions perdues) [2021]
(the part in bold is the one I can't currently automate as it's information held in the clipboard at the moment when the context_menu-->antrenamer_script is called.
Re: Rename based on clipboard content
That's a rather specific task. It is not much bulk-processing as originally intended by Ant Renamer.
For such specific uses there should be other ways to achieve it.
A few years ago, VBScript was good for that. I suppose that nowadays it is replaced by Powershell: using it you can easily make the commands that you want and access the clipboard when the script runs.
