problems with AMC when adding own info
xyncro
Post by xyncro »
hi.. :??:
..i'm not sure that i'm in the right category with this problem i have..
..but here goes anyways..
i have noticed that 'pipes' ( || ) appear when i'm adding info by myself..
i'm normally usually using any script to get the info i need
but..
sometimes i need to add info by myself, and it is at this occations the outcome looks 'strange'..
..i'm getting a | for every new row i make..
i'm using webtrack to display my moviecollection so i took this 'problem' up with the developer and they said it's not webtrack causing this 'error'
here is a sample (checkout plot and comments - this info was added manually)
is this something that is known and can be fixed..??
any help here is appreciated..
thx..
When exporting to CSV, XML, SQL and few others AMC puts "|" as newline character.
It is somewhat not the best solution, as I could use CDATA blocks for XML and \n for SQL.
But for current version it is the program that displays the data that has to replace the | by <br /> or any other needed character/string.
xyncro
Post by xyncro »
..thx for your answer..
