fout code
ben015
fout code
Post by ben015 »
ik kan niet meer uitprinten
ik krijg fout code:
access violation at adress 004229bg in module movie cataloge.exe read of adress 0000000c
error reading fr report form access violation at adress 00641595 in module movie cataloge.exe read of adress 00000030
hoe kan ik dit oplossen
It is quite hard to guess.
It was working previously? Did you change anything to your printers (default printer, driver, installed a virtual printer e.g. for PDF creation, ...)?
Maybe there is a corrupted print template. Try to move all the ".frf" files from the "templates" folder to another folder to see if it solves the problem.
ben015
Post by ben015 »
i have instals second printer
i havnt chance nothing
i have instal a new version and this wil not work
i must tel that in the new version movie/search on the internet there was a missing link : nl http://moviemeter.nl/?search&q=%s
so i copiet from a another harddisk these file to my windows bootdisk
catalogs languages
scriptt
templates
toolbars
amc report
fruser
media info.dll
unins000
amc report
fruser.cnt
movie catalog
unins000
amcexchange.dll
codecs
licence
and prefs
i can print agan
