Export to CSV options?
sracer
Post by sracer »
I noticed that AMC doesn't export to CSV exactly the same as other applications... in particular, it doesn't enclose fields in double-quotes (") if the field contains a comma (,). Most apps that I have used enclose everything in quotes (makes generating and processing easier).
Is there a way to do this in AMC?
Thanks!
It is not possible for the moment.
Actually AMC remplaces the separation character by another (there is an option for that in the export window)
