A Movie exist on www.35mm.it but the script cannot find it
colpito
Post by colpito »
Hello, I'm in trouble with this situation.
I'm looking for this movie " La casa - The Evil Dead ". If I search it by the
script, simply writing the word "casa" I cannot find it, but if I search it
directly on the website I fast find it at http://www.35mm.it/film/scheda.jsp?idFilm=5906
So the movie exists.
the question is : Can I try to get information for a movie directly by an
http address I know before?
Thanks for all who will answer to my big trouble.
Cheers
Colpito
Re: A Movie exist on www.35mm.it but the script cannot find
colpito wrote: the question is : Can I try to get information for a movie directly by an
It can be done if the script is ready for that.
For example, the IMDB script accepts that you past an URL instead of typing a movie title.
colpito
Post by colpito »
Thanks Antp,
I will try to use this your tip, in the afternoon.
Thanks, from Italy.
Colpito
