have some problems with v3502
xyncro
Post by xyncro »
hi.. :??:
after i have installed the new version v3502 i'm getting both original title and translated title on the same (display-) field.. is that normal..?
..or maybe this is a setting (which i can't find.. :/ )
i would be thankful for any help here because it can't look like this.. :ha:
thx
You mean in the main movie list, on the left of the main window?
It can be configured in the Preferences window, there is an entry "title format".
xyncro
Post by xyncro »
... :grinking:
thx.. now it's fixed.. maybe it was too easy for me to see where to make the changes..
..anyways.. now it works.. nice versatile app.. ;)
