Wrong Font Showing via Designer.
henrifos
Post by henrifos »
I love my AMC.
I found a small glitch I though that people may be interested in.
This happens when using Designer and only with some Fonts. I selected a True Type Font that I downloaded so that I could change the font of the Original Title.
If I choose the drop down font selector at the top of the screen below the File/Edit/Tools/? drop down menus, it changes to some standard (i think) basic looking font and not the one that is selected.
If I right-click on the Field, in this case "Original Title" and select "Edit" from the pop-up menu and then select my font IT WORKS.
Except that if it is already displayed, I have to change it to another font, save that, then come back in and change it to the font that I want.
I have version 3.5.0.2
It's still a great product. :innocent:
Interesting, I will check in the code what could explain this. Maybe some "initialisation" for the newly used fonts is missing.
But the designed was not made by me: it is a ready-to-use print tool that I integrated in AMC ;)
