upgrade
jmcan97280
upgrade
Post by jmcan97280 »
is there an upgrade
It depends what you want to upgrade.
If you have version 3.4, yes, there is a 3.5.0.2.
If you already have that one, no, it is the latest.
Only scripts have been updated since that version.
There is also a "beta" version:
viewtopic.php?p=18403#18403
I really should finish it...
