Problem with import from "Moviemeter"
wvd
Post by wvd »
Since yesterday I get the wrong information when I import from Moviemeter.nl with the script.
Could somebody change the script "MovieMeter (NL).ifs" so I get the right data again??
Wim
It seems to be since Sunday or something like that actually, there is a modified version on www.antp.be/temp/scripts
You can also modify the script yourself by searching in it for "Page.Count", which is followed by "-1" and put instead "-2".
wvd
Post by wvd »
Thank You, its so simple if you know what to do. :grinking:
Wim
