html file works on harddisk, but not online
JoZ
Post by JoZ »
Hello,
Yesterday i finally finished adding all my movies.Then i wanted to put everything online on my webpage, but it didn´t work and the page only shows that there occured some errors while loading the webpage. But if I click the index file on my harddisk, in the folder where all the other files are stored, everything works fine :ha:
Please help me
sorry i forgot to say: my version is 3.4.0
Which template did you use ?
It is more likely a problem in the template than in the program.
yeah, i know, i did a mistake by putting this subject in the "Bug reports".
I should have put it in the help forum!
Sorry.
I used Twink 0.8 but now i wanna use Willspos one, and I don´t understand the instructions in the readme exactly
There is a topic with few pages in the Help or the Templates section, and I think that you are not the first to have this problem...
But since this template is not from me I cannot really help you much more, sorry :(
aCCuReRaS
Post by aCCuReRaS »
I've tried Twink's template also first, and it didn't work online.
So I tried Willspo's template, and this one works fine! Online and on hd.
