Lost Movies
jmcan97280
Lost Movies
Post by jmcan97280 »
After I installed some movies earlier I went back to install more but it tells me cannot open because it cannot find the file that created the oringinal.
Sorry but I do not understand what you mean :??:
"Install movies", you mean add movies to the list?
And if it says that it does not find the file, I guess that you moved or deleted the catalog file...
