Importing from CSV - lots of mess
SimonM - Guest
Post by SimonM - Guest »
I have more than 600 movies and i've tried to import the list from excel, i did exactly as i should (choose column name, and clicked on column header) and instead of the order from excel i get all the movies messed up :( . Headers: Original Title, Polish Title, CD, Number)
By the way, the program you've made is gr8.
SimonM
It should keep the order from excel, especially if you import a "number" column
What do you mean by "messed up" ? Were the numbers and other info correctly imported ?
Titles are correct but the order is messed up, program uses its own order :(
Strange, I will check that later...
SimonM
Post by SimonM »
I've fund what is wrong :) all the numbers in excell i had were like this 121. 122. 123. and when i deleted these dots averything went smooth :)
Ok, nice :)
