Stupid question :)
Tolkien
Stupid question :)
Post by Tolkien »
Where did you found all the icons used in ant movie? :??:
(I said it was a stupid question...)
I'm starting to program and I was searching for some icons.
What I found 'till now did not satisfied me! :/
As I found yours pretty cool... (don't say you made them! :p )
Thanks anyway :)
The "Scrows" icons (the default set) come from www.virtualplastic.org/scrow ("glyphs" and "mo'glyphs" sets).
The Windows XP icones come from www.techmarc.co.uk/glyphspro.htms
Tolkien
Post by Tolkien »
Super merci! :grinking:
