How to get alternate image?
hrishikesh
Post by hrishikesh »
Hi ,
I have d/n the movie info from the IMDB for all of my movies , but I want to have altenative images for the few movies. Is there any way to do this through automated script? The images can be from any other sites also.
The ideal senario whould be
1) Select the movies for which you want alternative movies
2) Select some script and run it , which finally downloads 2/3 imges for the movie form various sites
3) Now select the move and choose from the images
I know it's free prog , but anything similar will be great !
As always .. Thanks for this wonderfull program
You can only have one image for each movie, and the script has no way to display multiple images to let you chose among them.
