How to install the program
player181
Post by player181 »
How to install the program? Please send help :??:
Re: How to install the program
:??: what's the problem / question ?
If you download the version with installer it works like most of the other programs
ThecknoDecker
Post by ThecknoDecker »
I can do a manual installation but I would like to automate it through SCCM.
Does any parameters exist to the antrenamer2_install.exe?
In order to tell it where to install and such and put it in quiet mode?
It does not seem to support any by default (I use InnoSetup), but you could create a different setup with the "portable" version, possibly using the InnoSetup config file provided with the source code archive.
