My amc/xml Database files got deleted it had over 1500+ English movies.
Can Somebody help by sharing there catlog files / telling me where can I get them ?
By this way I will have to import only few entries from IMDB
Please help
Thanks in Advance
Where can I get *.amc file as I have deleted my catlog :-((
hrishikesh
hrishikesh
Ok This is what I am doing
Not the easy way but atleast little easy way
1) Went to IMDB , added few movies in my movies
2) While doing this just search for matrix , it will show all 3 movies, add them to my movies . Just by 3 clicks through mozilla
3) Try also serching for actor , it will list all the movies for that actor actress , again mozila middle click
4) I created 200 movies in 20 mins through this way
5) copied the final html , did some editplus made csv file
6) Imported them in the program
7) Now Will start batch download for all the movies before going to bed
Anybody having better idea to do this pl. let me know
Maybe search on YEAR and Country, eg. 2005 & USA
http://www.imdb.com/ReleasedInYear?year ... ountry=USA
You can use Easy recovery (or othe similar software) to recover your file. You can recover it as if you have format your HDD
