Splliting name to subfolders
Bluescreen
Post by Bluescreen »
hello,
i have a little problem with your tool ant renamer.
i tried to rename the files in the following way
c:\testÍtest1Ínothing.mid
to c:\test\test1\nothing.mid
but i doesnt work.
is there any way to create subfolders from splitting the name ?
regards
Bluescreen
Bluescreen
Re: Splitting name to subfolders
Bluescreen wrote:hello,
but i doesnt work.
regards
Bluescreen
If the folders do not yet exist, you have to enable an option somewhere in the Preferences window to force the creation of the folders: by default it does not try to create each folder of the path if I remember well.
Bluescreen
ah ok now it works perfectly thanks ;)
btw nice handy programm ;)
