clone numer to media label
-=[WeBsEcReTa]=-
Post by -=[WeBsEcReTa]=- »
My catalog is until I number 872. How I can clon the number of movie to media label? for all
Mi catalogo es hasta el numero 872. ¿Cómo puedo clonar el número de la pelicula a código de registro? para todos
using the following script:
program NewScript;
  SetField(fieldMedia, GetField(fieldNumber));
-=[WeBsEcReTa]=-
Cool, thank you very much :P
-=[WeBsEcReTa]=-
It is possible to be modified to put something before the mumber for example:
456 ==> mov-456
Se puede modificar para poner algo antes del mumero por ejemplo:
456 ==> mov-456
  SetField(fieldMedia, 'mov-' + GetField(fieldNumber));
or if you want to add it to the existing media field, replace fieldNumber by fieldMedia
-=[WeBsEcReTa]=-
thank you very much my friend :grinking:
