Wrong movie name
pollewops
Wrong movie name
Post by pollewops »
When I add a movie called "A Bug's Life" and do a Save As XML, then in the XML the movies is called "A Bug's Life"
How can I solve this ?
Both name are identical :??: Did you enter & # followed by a number, which was converted to a « ' » ?
If yes, that's probably because in the XML some special characters are stored like that, but I do not see why this would be a bug...
pollewops
Post by pollewops »
Yes I see...i was trying to put the code in here, but it is changed to the original ' again :-)
I use the XML file in the php application WebTrack and there it displays the code instead of the character....
Try to put a space after the "&" so it is not converted ;) (to check that it is the normal code of the « ' »)
Maybe it is a problem of the PHP application then :??: As far as I know the XML file generated by AMC is valid.
