suggestion for the commandline
Hubertus
Post by Hubertus »
I like your program very much, it is a great tool :grinking:
I have a suggestion for the commandline:
"Renamer.exe -afr d:\Data" works
"Renamer.exe -afr d:\Data\" works not
I need the second, because I will integrate your tool in the buttonbar from the Total Commander.
Hubertus
Strange that it does not work :??: I'll check that, thanks for the info ;)
