Hello everybody
Have you somethning to directly rename french filename (accent, ... ) to Linux filename without accent
Best regards
rename filename
Re: rename filename
What do you mean by "directly rename"? At which moment?
If you want to rename multiple files easily there is my other program, Ant Renamer
