about modifing a template
plus
Post by plus »
I modified a template (the alcast catalogue) so that it includes also the media label field (add rectangle object-> variable= medialabel).
I filled up the media label field with a text string but in the printing preview I don't see this text.
Could you help me to solve this? When am I wrong?
Thanx you and thanx for your great software!
massimiliano
p.s.: sorry but I can't write french :(
Is the added rectangle located on the same "Master data" band as the other rectangle fields?
plus
Post by plus »
yes, it's inside the bigger rectangle band named master data....
massimiliano
And it has the same style as other rectangles, i.e. the field name between [...] ?
plus
I found my error
Post by plus »
this just to tell ya I found my error so it was not a bug of your software... :)
simply, the variable inside the rectangular box was [label:medialabel] and not [medialabel] as it should be!
anyway thanx again for your very good progr!
plus
