filmaffinity labutaca
darts501
Post by darts501 »
boths scripts dont work , could you check somenthing
folgui
Post by folgui »
Hello!
Filmaffinity works perfect for me. Tried with several films and all ok. Get the latest version from the link posted by antp below.
LaButaca doesn't work correctly. A deeper analysis is needed, don't have time now, sorry.
Regards, folgui.
The FilmAffinity script that I have on http://antp.be/temp/scripts/ seems a little different... I do not know which one is the good one actually.
folgui
Post by folgui »
antp, you have the latest version and works perfect so, i've deleted what i posted above.
Sorry, if i've created more confusion with my post ;)
Regards, folgui
No problem, thanks for the info ;)
darts501
fillsfinity
Post by darts501 »
wich post is good. i prove with http://antp.be/temp/scripts/FilmAffinity%20(ES).ifs and dont work,
folgui
Post by folgui »
Why it doesn't work? I've searched several films with it without any problem. I'm talking about version 2.3 that is in antp's temporal directory.
Regards, folgui
doctordri
Nice
Post by doctordri »
FilmAffinity version 2.3 works fine for me. Great job, thank you.
Especialmente útil el modo rápido para mi larga lista de pelis a actualizar ;-)
