modification which inserts codec of video, audio and the resolution. This prepared for when data can be extracted but
Authors=Icecubix - modifi. VicAnna
Title=SDG (ES)
Description=Movie importation script for SDG
Site=http://www.sdg-es.org
Language=ES
Version=2.0
Requires=3.5.0
Comments=Versión reescrita de cero (SDG-es.com --> SDG-es.org)
program SDG;
BaseURL = 'http://www.sdg-es.org/foro/sdge.php';
BaseURL2 = 'http://www.sdg-es.org/';
ModoBatch : boolean;
BuscarCaratula : boolean;
Result := -1;
if StartAt < 0 then
StartAt := 0;
if Pos(AnsiUpperCase(Pattern), AnsiUpperCase(List.GetString(i))) <> 0 then
Result := i;
InitialPos: Integer;
longEnd: Integer;
if( Length(EndTag)>0) then
InitialPos := Pos(EndTag, S);
Delete(S, 1, InitialPos + 1);
result := copy(S, 1, Length(S));
function TextBetween_noDelete(S: string; StartTag: string; EndTag: string): string;
InicioPos: Integer;
s2: String;
S2 := S;
InicioPos := Pos(StartTag, S2);
Delete(S2, 1, InicioPos + Length(StartTag) - 1);
InicioPos := Pos(EndTag, S2);
result := copy(S2, 1, InicioPos - 1);
procedure BuscarPelicula(Nombrepeli: string);
Line, LineAux: string;
Elementos: Integer;
Item: string;
Enlace, Titulo, Linea: string;
s1, s2: string;
i1, i2: integer;
Page.Text := PostPage(BaseURL, URLEncode('do=buscando&busquedarapida=1&cadena=') + Nombrepeli);
if Pos('<strong><a href="sdge.php?', Page.Text) = 0 then
ShowMessage('No se ha han encontrado películas por "' + Nombrepeli + '"');
Page.savetofile('d:\borrar1.html');
if not ModoBatch then
LineNr := 0;
LineNr := FindLine('<strong><a href="sdge.php?', Page, LineNr);
PickTreeAdd('SDG. Películas por: "' + MovieName + '"', '');
while LineNr > 0 do
Linea := Page.GetString(LineNr);
Titulo := TextBetween_noDelete(Linea, '">', '</a>');
Enlace := TextBetween_noDelete(Linea, 'a href="sdge.php', '">');
Enlace := BaseURL + TextBetween_noDelete(Linea, 'a href="sdge.php', '">');
s1 := 'sdge.php?s='; i1 := pos(s1, Enlace);
s2 := '&do=verelink'; i2 := pos(s2, Enlace);
if (i1 > 0) and (i2 > 0) then
Enlace := copy(Enlace, 0, i1+8) + copy(Enlace, i2+5, length(Enlace));
PickTreeAdd(Titulo, Enlace);
LineNr := FindLine('<strong><a href="sdge.php?', Page, LineNr+1);
if PickTreeExec(Enlace) then
AnalyzePage(Enlace);
function AnalyzePage(Address: string): Integer;
LineNr, LineNrAux, aux, numCds, found, multiplier: Integer;
Size, SizeLimit: Double;
Item: string;
Comments: string;
Actors: string;
Description: string;
isDual, isSubtitExt, isSonidoExt: Boolean;
Idiomas: string;
Subtit: String;
strAux: string;
delimiter: string;
SonidoExt: string;
TitOriginal: string;
Comments := '';
Actors := '';
Description := '';
// URL
// Titulo traducido
Item := buscaCampo('Detalles del Elink', 0, '>', '</a>');
// Caratula
LineNr := FindLine('>Información<', Page, 0);
LineNr := LineNr + 8;
Item := TextBetween (Line, 'imagenes/elinks/', '"');
GetPicture (BaseURL2 + 'imagenes/elinks/' + Item);
// Descripcion
Item := buscaCampo('<b>Descripción:', 1, '<br>', '');
// Titulo original NO HAY!!
//SetField(fieldOriginalTitle, Item);
// Direccion
Item := buscaCampo('<b>Dirección:', 0, '</b>', '');
// Interpretacion
Item := buscaCampo('<b>Interpretación:', 0, '</b>', '');
// Genero
Item := buscaCampo('<b>Género:', 0, '</b>', '');
// Duracion
Item := buscaCampo('<b>Duración:', 0, '</b>' , 'min');
// Pais
Item := buscaCampo('<b>País:', 0, '</b>', '');
// Year
Item := buscaCampo('<b>Año:', 0, '</b>', '');
// Resolucion
Item := buscaCampo ('<b>Resolución:', 0, '</b>', '');
SetField(fieldResolution, Trim (Item));
// Video Codec
Item := buscaCampo ('<b>Video Codec:', 0, '</b>', '');
SetField(fieldVideoFormat, Trim (Item)) ;
// Audio Codec
Item := buscaCampo ('<b>Audio Codec:', 0, '</b>', '');
SetField(fieldAudioFormat, trim (Item));
// VideoBitrate
Item := buscacampo ('<b>Bitrate:', 0, '</b>', '');
SetField(fieldVideoBitrate, trim (Item));
// AudioBitrate
Item := buscaCampo ('<b>Bitrate:', 2, '</b>', '');
SetField(fieldAudioBitrate, trim (Item));
// Tamaño
Item := buscaCampo ('<b>tamaño:', 0, '</b>', '');
SetField(fieldSize, trim (Item));
function buscaCampo(patron: String; offset: integer; ini, fin: string): String;
i, LineNr: Integer;
Item: string;
Result := '';
LineNr := FindLine(patron, Page, 0);
if LineNr > 0 then
LineNr := LineNr + offset;
Item := TextBetween (Line, ini, fin);
HTMLDecode(Item);
Item := Trim(Item);
//borramos el punto final, si lo hay:
i := Length(Item);
if copy(Item,i,i) = '.' then
Item := copy(Item,0,i-1);
result := Item;
if CheckVersion(3,5,0) then
BuscarCaratula := true; //getOption('BuscarCaratula') <> 0;
ModoBatch := false; //getOption('ModoBatch') = 1;
if ModoBatch or Input('Importar de SDG', 'Introduzca el titulo de la pelicula:', MovieName) then
if (Trim(MovieName)<> '') then
BuscarPelicula(UrlEncode(MovieName));
ShowMessage('Este script requiere una version mas reciente de Ant Movie Catalog (por lo menos la version 3.5.0)');
