BETA FIX - Imdb Large Pics
lboregard
Post by lboregard »
the solution below has worked with all of the movies i've tried. i hope you could test it, to have it "certified" :)
// Picture
LineNr := FindLine('title="DVD available at Amazon.com"', Page, 0);
if LineNr > -1 then
BeginPos := Pos('href="', Line) + 5;
Delete(Line, 1, BeginPos);
EndPos := Pos('"', Line);
AmazonPage := TStringList.Create;
AmazonPage.Text := GetPage('http://us.imdb.com' + Value);
LineNr := FindLine('<title>Amazon.com: DVD Search', AmazonPage, 0);
if LineNr < 1 then
LineNr := FindLine('img src="http://images.amazon.com/images/P/', AmazonPage, 0);
if LineNr > -1 then
Line := AmazonPage.GetString(LineNr);
BeginPos := Pos('img src="http://images.amazon.com/images/P/', Line) + 8;
Value := StringReplace(Value, 'TZZZZZZZ', 'LZZZZZZZ');
GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
BeginPos := Pos('<title>Amazon.com: DVD Search Results: ', Line) + 38;
EndPos := Pos('|', Line);
Value2 := Copy(Line, 1, EndPos - 1);
Value := 'http://images.amazon.com/images/P/' + Value2 + '.01.LZZZZZZZ.jpg';
AmazonPage.Free;
LineNr := FindLine('<img alt="cover" align="left" src="http://ia.imdb.com/media/imdb/', Page, 0);
if LineNr < 0 then
LineNr := FindLine('<img alt="cover" align="left" src="http://posters.imdb.com/', Page, 0);
if LineNr < 0 then
if LineNr > -1 then
BeginPos := pos('src="', Line) + 4;
EndPos := pos('"', Line);
Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ'); // change URL to get the Large instead of Small image
Thanks, I will try that ;)
Dr Greenthumb
Post by Dr Greenthumb »
Thx for the code but I can't seem to get it working.
I get the following error message:
Script error : IMDB at postion 4298 (unknown identifier : AMAZONPAGE)
:cry:
lboregard
Post by lboregard »
sorry ... u need to declare the variable at the top of the script :
before
BeginPos, EndPos: Integer;
after
AmazonPage: TStringList;
Dr Greenthumb
Excellent, its works like a dream now. Thx a million Dude!!!!!!!
:grinking: :grinking: :grinking:
Flash
Post by Flash »
good work !
but in "harry potter 2 and the chamber of secrets" i 'only' get a small picture ... dont know if that's a bug or if there just isnt any bigger pic available
but anyway, thanks for coding :D
Since the DVD is not available yet I guess that Amazon.com does not have it yet on its site, and so it is not possible to get the large image from Amazon :D
lboregard
BETA FIX UPDATE - Imdb Large Pics
Post by lboregard »
i changed the parsing of the amazon page, to make the script more accurate ....
// Picture
if LineNr > -1 then
// if Pos('<TITLE>Amazon.com: DVD Search', AmazonPage.Text) = 0 then
LineNr := FindLine('<b>1.', AmazonPage, 0);
if LineNr < 1 then
if LineNr > -1 then
LineNr := FindLine('http://images.amazon.com/images/P/', AmazonPage, LineNr);
BeginPos := Pos('src="', Line) + 4;
Value := StringReplace(Value, 'THUMBZZZ', 'LZZZZZZZ');
AmazonPage.Free;
if LineNr < 0 then
if LineNr < 0 then
if LineNr > -1 then
You should use [code] tags to get a better formatting of your code :
[code]
place here the code
[/code]
lboregard
Post by lboregard »
ok .. here it goes :)
  // Picture
  if LineNr > -1 then
    if LineNr < 1 then
      if LineNr > -1 then
    AmazonPage.Free;
    if LineNr < 0 then
    if LineNr < 0 then
    if LineNr > -1 then
The Nutty Professor 1963 comes out as a blank white picture with this code..
Man Who Knew Too Much, The (1956) brings the wrong photo from amazon.com, the set dvd, instead of the actual movie...
same problem with "Stalag 17" brings collection, instead of actual film..
I'll check that
luckybigpack
Post by luckybigpack »
Same thing for several other movies like Aliens 1-4 or MiB1+2 and so on...but I tried it with my whole Database (500 Movies) and maybe 20 got a wrong picture. The right movie but the collections pictures.
For this collection problem I am not sure that it is possible to do better, it is probably because the first item on amazon is a collection thing.
Well I will see that later, within few days I think ;)
