Read timeout error
MOMAtteo79
Read timeout error
Post by MOMAtteo79 »
I have a huge database with almos 1800 movies, when i try to update a new movie with new datas from imdb (italian or not) i get a read timeout error, any idea why?
Both are not related, this is probably a temp problem with IMDB. Does it work for other sites?
MOMAtteo79
i tought it was cause i tried same movie in new catalog and seemed to work.
I made another try and id dind'nt work either, btw other scripts seem to work, but i need imdb lol :)
do you have any suggestion apart from trying later? it's a few days i have this kind of error
it often happens ad same point when saying
downloading 32768 bytes
if i insert in the search field of antmc the url of the movie previously found in imdb instead it always import fine
There is really no reason why it would fail for your catalog and not for a new one :??:
MOMAtteo79
ok tmx, so i keep my catalog growing :)...
