Bug in HTML export with duplicated number
music0
Post by music0 »
I have duplicated numbers in my film's list. When I export to HTML then pictures are the same at all positions with the same number.
This is a known bug. For the moment, the only workaround if you want to use duplicate numbers is to change the filename style in the Preferences (Tools -> Preferences -> Export).
