Add folder by path
Moop
Add folder by path
Post by Moop »
Its a pain to navigate with file picker from the drive path all the way to the folder. Why not add folder by absolute path?
Re: Add folder by path
Indeed I don't know why I haven't added that possibility.
Maybe I'll add that next time I do an update, but note that you can also add the folder via drag & drop from Windows Explorer (or other file manager application).
