Can't fill in the title
pluus_x
Post by pluus_x »
I just started to use this program because everywhere it is said or written that it is a good movie catalog.
It looks to me a stupid question, but when i add a movie i can not add/edit (in the leftmost panel) the title.
This seems to me very important. The import from the menu movie/get information/from script (then IMDB) does not work at all. Maybe because there is no title?
The help from the program unfortunately says nothing about this neither.
You have to type the information in the right panel. The left panel only displays what has been filled in the right one.
When you say that the script does not work, what did you do in the script window and what was the error/behaviour ?
pluus_x
Post by pluus_x »
Tnx, for your help. Indeed fill in the filed "original Title" in the right panel and it appears in the left pabnel. I had onlyfilled in the field "media label" the first ( and so i thought most important) field.
Concerned about the scripst: my fault, i pressed the ok button instead of double clicking. ( but what does ok then?)
The OK button is to validate the imported data after they have been retrieved from the web.
