Reverse Renaming + Enumeration
Phillyman
Post by Phillyman »
I would Gladly Donate if you can add this small feature
I have an extensive videogame magazine collection .....unfortunatly i hate how much room it takes up .....and i am in the progress of scanning my magazines into electronic format
Debinding the magazine and running it thru my scanner .....with the cover up .....that scans the odd pages .....and i can use your program to rename and enumerate by 2
001
003
005
...etc
Problem is ....when i flip the magazine over to scan the EVEN pages ......now the magazine is upside down .....with the last page first!
I need a reverse renamer with enumeration!
Basically it would do this.....
Ask User for what prefix
Nintendo Power Issue 160 -
Then it would calculate how many images were in the folder
66
Then it would start at
Nintendo Power Issue 160 - 0001.jpg and rename it to Nintendo Power Issue 160 - 0132.jpg
Then rename Nintendo Power Issue 160 - 0002.jpg to Nintendo Power Issue 160 - 0130.jpg
Enumerating backwards by 2 each time
I appriciate this ......and will definetly donate for this program .....NOTHING out there does this ......and i can use this feature :grinking:
If you do a reverse sort on the name in main list (by clicking on the "filename" column header), and put a step of 2, it will probably work the way you want.
Phillyman
Post by Phillyman »
Donation should show up in your mailbox shortly
Thanks A Ton!
Keep up the fantastic work!
