Lenght import is corrupt
aCCuReRaS
Post by aCCuReRaS »
First I wanted to say that it is a great program :)
Now the bug:
Program version:
-> 3.4.0.18 (moviecatalog.exe)
-> 1.0.1.2 (AMCExhange.dll)
Script:
IMDB Import (large image)
Problem:
The movie lenght seems to be wrong if the lenght < 59 minutes.
And I think that he counts +- twice the lenght, dunno how it comes, but it isn't ok!
If you check the lenght in you're program and then on imdb, you'll see that it is wrong.
Plz bugfix :)
Thanx in advance
This is probably a very minor problem ;)
Could you please give me a title of movie that gives such error ?
aCCuReRaS
Post by aCCuReRaS »
most of them give that error :)
K19: The widowmaker
Face Off (in program: 247min - imdb: 138min)
The Negotiator
Apollo 13
Fight Club
The Matrix
Do you need more? Tell me :)
Are you sure that you do not import info from a .AVI after that ?
If you do, remove the "import length" in Tools -> Preferences -> Get information, or import info from .AVI before IMDB.
When importing from a video file it adds the length instead of replacing it because there may be several files.
aCCuReRaS
Post by aCCuReRaS »
oooh, yes!
that's it. I didn't notice that the program import lenghts from the avi file.
thanx!
