How to set an empty value with setField?
Nik0
Post by Nik0 »
i tried to clean my comments fields with the command
SetField(fieldComments, '');
but the new value was not stored in the database.
SetField(fieldComments, 'aaa'); would work, but this is not what i want to have.
What's the clue? :D
There is an option "allow to clear fields" (it was added by request of users because in most of the case there is no reason for the script to clear a field)
Nik0
Post by Nik0 »
Ah, thanks! Perfect solution as usual. :)
