SQL Problem ...
anton
SQL Problem ...
Post by anton »
Hello,
I don't know if I messed up, or there is a bug in program, but in my SQL base I found that some fields are swapped , here they are:
FrameRate=Resolution
Languages=Frame Rate
Subtitles=Languages
Resolutions=? (maybe Subtitles)
Any help ?:)
Which version do you have ? (version + date)
It was a bug but I think that I corrected it already.
anton
Post by anton »
3.4.0 (19/09/2002)
yeah, probably I will need to upgrade :)
Yes I corrected that in October or November ;)
