IMdB pics worked yesterday, but now...
ElGregos
Post by ElGregos »
well I can get none of them, even by trying to retrieve again movies I've entered yesterday. I've changed nothing to my script, so I guess IMDb has changed something to their DB. Am I the only one to have this problem ? Anyone knows what to do ? Something to modify in the script, maybe ?
Cyriaxx
Post by Cyriaxx »
I have also Problems with the Scripts OFDb and OFDb - IMDb.
I can enter a word to search, and reveice a list with the films attaching to it, but when I select a film all the detail infos are empty. Anyone who knows what to do?
Greetings, Cyriaxx
MOMAtteo79
Post by MOMAtteo79 »
Same here, can't import pics from italian imdb
Which option do you use for "ImageKind"? (so I do not have to test all of them if only one fails)
skyalex
Post by skyalex »
The same here as Cyriaxx said.
Trying to get info by OFDb or OFDb - IMDb I can select the title, but the results are empty. Trying with script Cinefacts (also a german one) it works perfectly.
Alex
ElGregos
Post by ElGregos »
Hi Antoine,
My option for "ImageKind" is 1 (IMDb small image from main page)
I'll try to fix that this week-end, unless somebody else does it before me ;)
I fixed the problem with small picture:
http://www.antp.be/temp/scripts/IMDB.ifs
If some people could try it on few movies it would be nice.
If there are problems with some movies, or for the other picture kinds, please list few movie titles so I can quickly detect the problem ;)
ElGregos
Post by ElGregos »
I've just checked on some movies, it works perfectly ! Nice work again, Antoine, thanks !
erhnam
Post by erhnam »
I had no images and now with this new script I have the same problem as Cyriaxx: I get a list to choose from and then no details come back :(
Cyriaxx
Post by Cyriaxx »
Hello erhnam,
look at OFDb script fix for the problem with the empty fields.
But I also get no pics ...
Greetings, Cyriaxx
pillem
Post by pillem »
I entered twenty movies and the only movies without a picture were the ones where IMDB itself didn't show a picture. AntMovie works well again. Good work, Antoine. Thanx.
scottdw
Post by scottdw »
I had a problem with it using the us.imdb.com url. I removed the us part in all lines that had it so it just reads imdb.com and mine is now working, but I do not pull pictures from imdb (I use amazon) so I cannot comment on that. I would attach my script file but I don't think you can.
Hope this helps.
