Importing information from AVI tags
Kibi
Post by Kibi »
Some time ago I wrote you a request for AVI tags support:
viewtopic.php?t=814
I see you've made MediaInfo library since that time - that's good news to me. :))
I've written some export templates for abcAVI Tag Editor (export to AMC XML format), but it's only the hack.. Also some improvements in abcavi.dll were done - it's using in Windows Info Tips shell extension and Google Desktop Search AVI indexer plugin at present time.
Could you please describe what's the situation with importing information from AVI files to AMC? I mean textual info, not technical.
Importing AVI info is still on my todo list since that time :/ :D
What kind of "situation description" do you want?
