Database too big ?
Mahimahi
Database too big ?
Post by Mahimahi »
Hi,... first post here :)
I'm using movie catalog for over 4 years but now I'm running into problems.
the program blocs my PC entirely after a few operations. The database-size is now 70 MB.
When this happens I can see that movie catalog uses 99% of all the resources.
I upgraded to the latest version but that didn't help either.
Anyone an idea?
Thx in advance,
Mahi
This should not be related to the database size.
Several people using a nvidia video card had similar problem, do a search on the Bugs section to get more info.
If you have a nvidia card, try to upgrade drivers and/or disable nview desktop to see if it solves the problem.
