For the next version....
Oper
Post by Oper »
I sent you an email with all of this things... but I better put them here with all the others suggestions, don't you think ? :)
* Error ? Bug ? :
When the list of the movies appear, if you don't click in one of them in a few seconds (4 or 5...) this error message appears:
"Connection Closed Gracefully"
What does it means ?? is a program bug or is a web page problem ??
* suggestion:
when you import pictures with the parameter "True" the program copy the picture file in the same directory than the catalog is stored. Is it possible to store them in the directory for pictures saved in the preferences? and put then the movie name o the Translated movie name ??
p.d. when will you make a new release ?? all of we are waitting.... :hihi:
The "Connection Closed Gracefully" is, I think, a problem with your connection or your ISP. I do not know exactly why it happens and how to reproduce it since I never had this error.
As I said in the mail (I think it was you) :
For the picture file name, I will add in a future version the possibility to choose the file name. Currently it uses the name that the picture has on the website.
I also have to add an option to select the folder, etc...
I do not know when the next version will be released : I have lots of ideas of things to add, but not so many free time :/
